What if i have zero knock count?
Old Apr 7, 2007 | 11:35 AM
y5mgisi's Avatar
Car: 90 Chev Suburban 4x4, 5.3L, th400
Engine: 2002 5.3 Vortec swapped in.
Transmission: Stock th400
Axle/Gears: 10blt front/ 14bltSF rear 3.73 gears.
I drove around for about 20 minutes with one of those little autoxray's, And never got a knock out of it. Could this possibly indicate a faultyknock sensor? Or is it sometimes normal to have zero knock? Thanks for the help!
Old Apr 10, 2007 | 12:52 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Re: What if i have zero knock count?
what is your timing set at? the lower it is set the more chance of not having a knock.
Old Apr 10, 2007 | 11:45 AM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
You could advance the timing enough to force it to knock, and see if you record counts then. That's how the stock ecm's test themselves.
Old Apr 10, 2007 | 01:41 PM
y5mgisi's Avatar
its set at 4* base. You soppsoe that if i were to tap on the block with like a wrench or hammer that it would register as a knock?
Old Apr 10, 2007 | 02:09 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
yup.
Old Apr 10, 2007 | 02:34 PM
y5mgisi's Avatar
Maybe i'll run up and try that real quick then. Of coarse that wouldent casue a rough idle/ idle surge situation anyway but i suppose it would be good to find out anyway.
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
spartanreaper
Sep 25, 2015 07:22 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
