Could a code 43 cause a rough idle situation?
Old Apr 7, 2007 | 08:58 PM
y5mgisi's Avatar
Car: 90 Chev Suburban 4x4, 5.3L, th400
Engine: 2002 5.3 Vortec swapped in.
Transmission: Stock th400
Axle/Gears: 10blt front/ 14bltSF rear 3.73 gears.
I know that code 43 is knock/esc related. But could this casue a rough idle or is the timing at idle just set at on point? Trying like crazy to fix this stupid surging at idle issue for about 5 months now and still not getting anywhere.
Also if i unplug the esc should i notice a differnce in idle quaility? becase i did that and i didnt notice any change.
Old Apr 7, 2007 | 11:15 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Could a code 43 cause a rough idle situation?
Spark retard isnt allowed when the engine is idling, so if there is a code 43, it shouldn't effect the advance at idle.
Old Apr 8, 2007 | 11:20 AM
y5mgisi's Avatar
ok thanks man!
chazman
Aug 28, 2018 03:25 PM
db057
Sep 4, 2015 07:57 AM
JHX
Aug 29, 2015 02:30 PM
