Bouncing oil gauge?
Old Sep 4, 2001 | 04:57 AM
ZRATED's Avatar
Bouncing oil gauge?
I have put in new lifters, timing chain and cover, and the cam off of a 1996 z28. With all that installed I still have the oil gauge bouncing up and down from time to time. It gives a little jump from 30 to 50psi and then back up it looks likes it has a mind of its own!!!!
One Tight Teal green 91 RS (my first car
All Rustangs suck!!!!
5.0 TBI with Auto trans
Z-28 wheels
K&n with dual snorkel intake
Tx Smog Pump Delete option
Rapid Fire plugs with Accel ignition wires,coil,cap and rotor
Flowtech headers with flowmaster and Half way cutout
B&M shift kit with trans cooler and hurst hotshift fulid
Hypertech thermomaster chip
96 LT1 cam
All the free TBI mods
Old Sep 4, 2001 | 08:12 AM
1991camaroRS's Avatar
This happened to me towards the beginning of the summer. Turns out the oil sending unit was shot. My oil gauge was always bouncing around. Sometimes it would go all the way to the right and just sit there. But that may be your problem. Hope that helps
1991 Camaro RS (Red)
PERFORMANCE
-Custom quad exhaust
-Edelbrock 14x3 open air element w/ 5" high K&N filter
-K&N X-stream lid
APPEARANCE
-TTops
-4" Cowl induction hood
Old Sep 4, 2001 | 09:46 AM
JPrevost's Avatar
Car: 91 Red Sled
Sounds like a bad sender or maybe a grounded/melted wire on the exhaust. Double check the wire and if that isn't it, replace sending unit.
, Jon (350 TBI!)
91 Red My website
Old Sep 4, 2001 | 03:01 PM
88firebird305's Avatar
Yep I had the same problem. My gauge would start out high drop down to 0 the go back up to 30 the it just stopped. After look through the boards deceided to change the sending unit(the bell shaped one at the top back of the engine next to distributer) and it solved my problems right away.
Old Sep 4, 2001 | 03:40 PM
firbird's Avatar
what if it is not there, the little ledge off the engine block sticking out from the intake manifold? one my T/a there is one back there but one my 92 lo3 firebird there is not and my sensor is screwed, so i just put a aftermarket one in that little hole behind the dist. and it works just fine, but i cant figure where is the orignal sender i prolly look at it every day and not even notice it.
Old Sep 5, 2001 | 06:24 PM
sunbitz's Avatar
Car: 91 RS Convertible
Engine: 305 TBI
firbird....
Have you looked right above the oil filter?
That's where the oil sender is on our 91 RS.
It's a real pain to get out though.
Old Sep 5, 2001 | 06:54 PM
firbird's Avatar
yea, i thought so i just thought that was something else but i was thinking that was the only thing it could be cause i took my engine out and exhanged all of the sensors and i knew what every one was but was not really sure what that one was but i thought it was something else, somewhere i herd that there was something that if your oil filter got blocked that a valve would open and bypass the filter so i just thought that was it.
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
