This engine is driving me nuts!
Old Sep 13, 2001 | 11:30 PM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
Ok, I have a 305 TBI with the Edelbrock Performer TBI intake manifold, SLP 1 5/8" headers, 3" exhaust with no cat, flowmaster 80 series muffler, MSD 6AL ignition box, MSD Blaster GM coil, T-5 5 speed, a decent clutch, Nitto DR's 275/50/15, and an open element. the gold ring was removed from the TBI unit and the open element air cleaner assembly is a flat base type. The rear gears are 3.08's but it does have posi. I also have Lakewood LCA's and an Edelbrock panherd rod, and Lakewook 50/50 rear drag shocks.
Now you know what I have, tell me what I should be running in the 1/4 mile. Right now it only wants to run in the mid 15's, I know it should be better then that. I havent burned a chip for it, and I don't want to. I have an adjustable fuel pressure regulator for TBIs sitting in my garage, do you think it could help any? Does the ultimate TBI mods actually do anything to make more power?
I know these are odd questions, but their the one's bugging me right now.
Old Sep 14, 2001 | 07:56 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Actually that AFPR would probably wake ur car up a lot. The stock fuel pressure setting is still being used, yet ur running 1-5/8" primaries,full 3" exaust w/o a cat. Thats a lot of air being rushed out of that engine and I doubt enough fuel,atleast at factory psi,can keep up with it. I bet if u boosted ur fuel pressure you would feel a big difference. I have a AFPR sitting in my garage as well that I need to install. My exaust setup is the same as urs except I have Edelbrock TES (TPI) headers.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Old Sep 14, 2001 | 11:13 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
the only mods helping your time are manifold, exhaust, posi, and your suspension. Check your plugs, hows your car running other than times? crappy?
you should be low 15's, high 14's. I think that you should boost your pressure, or go with a vacuum adjustable regulator. mid 14's then, because if you are runnin lean at wot, then your timing is being retarded, and thats why your are runnin so crappy.
edit, clarify, runnin lean at wot is causing knock, causing timing retard up to 14 degrees most likely, since you have a stock chip. custom chip, i know you dont want to, but thats the real tuning, if you dont want a custom chip, why not go carb. honestly. it may be better for you, if you are racing more than driving.
[This message has been edited by snflupigus (edited September 14, 2001).]
Old Sep 15, 2001 | 04:25 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Thats pretty impressive. How about putting steeper gears on?
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Omega
Oct 1, 2015 02:20 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mustangman65_79
Aug 8, 2015 12:07 PM
