Ok Ive searched, no luck
Old Apr 12, 2007 | 02:54 PM
The White Knight's Avatar
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Transmission: 200C 3 Speed
Axle/Gears: 2.93 Open Diff
I was gettin code 23, so I replaced my MAT sensor, no more engine light, car runs great.. when warm
After you let it sit for a little, it bogs when you initially give it the gas off the line (if you hammer it its not as bad) but normally pulling away it stutters
Sometimes it surges when it idles aswell
Any Ideas?
The EGR diafram is very tight I cant really push it in (Its the circular thing on the intake manifold, and I should be pushing at the bottom of it right?)
Old Apr 12, 2007 | 03:57 PM
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Re: Ok Ive searched, no luck
Also, should there be vaccuum at the EGR valve during idle.. like I pull it off, no differene, put my finger over it, no suction...should there be?
Old Apr 12, 2007 | 04:35 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Stinger
Of iddle response:
Of idle response ‘shutter’ may involve several items.
I would check TPS for worn spot right were throttle transitions from idle to of-idle position. A TPS sensor is mounted on the right hand side of the throttle body and has a three pin connector. TPS sensor is nothing more than variable resistor with it shaft coupled to the throttle shaft. You can remove TPS and check it with DVM. If there is a worn spot there will be a sudden jump in resistance between pin 1 and 2 as you very slowly rotate the shaft. These things do wear out with time.
RF
EGR operation is covered here:
https://www.thirdgen.org/egrdiagnose
Old Apr 12, 2007 | 05:31 PM
86firebird350's Avatar
Car: 91 GTA
Axle/Gears: stock
might also be a clogged fuel filter. have you checked that recently?
F-body-fan
Jan 12, 2023 01:49 PM
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
paul_huryk
Oct 1, 2015 04:27 PM
kkirch15
Sep 30, 2015 04:44 PM
