What should I do?
What should I do?
Ok, My rear end seals have been leaking for a long time now, and I finally have money to fix it. But, should I do gears too? Right now I have 3.08, I have no clue about gears and want to know what gears would be good for a daily driver. Or should I call some junk yards and find a rear end for another Camaro or TA and use it. If I do that I want to go with posi, but what years and models came with a good set of gears and posi traction. What should I do?
Kris
Blue 1989 TA
305 TBI
5 Spd.
Kris
Blue 1989 TA
305 TBI
5 Spd.
get a SLP posi, and a rear end from a newer 3rdgen v6. They will have the right spline count and better gears.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
-Tas
'89 Formula WS-6
:Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
The slp posi is at http://www.slponline.com/view_produc...TNUMBER=64501T
The gears I would go with is 3.42 if you plan on doing a lot of highway cruising or 3.73 if you to do a lot of playing with rustangs at stop lights. Your 89 could have 28 spline axles already. They aren't hard to pull and check.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
** Added so far **
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Why is the SLp posi so cheap? Is it weak? Powertrax and other companies are like $500 bucks. What is the difference between the two. They both put power to both rear wheels right?
1990 RS 305 TBI T-5
.5" turbocity spacer
Edelbrock TBI intake
180* stat
Summit 14X3 OpenElement W/k&N
Hooker 3" Areochamber
MSD - Wires, Cap, Rotor, Coil
Bosch Platinum +4 plugs
Metallic Red w/28,000 Pampered miles
(Still have the original wiper blades)
1990 RS 305 TBI T-5
180* stat
Car: '92 RS
Engine: In pieces
Transmission: Built 4L60
The reason they they are so cheap is that they are Takeoffs from Newer Z28's When they upgrade them to SS they get the Zexel HD unit most of them have 4-5 miles on them. They a pretty much NEW.
-Lars
-Lars
lockers can be dangerous. I've had the rear end come out on a wet mountain road and I have no limited slip. A locker or limited slip would have been much worse. My friend gave me mad props for saving it and not spinning out.
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
Car: '90 RS
Engine: 377 LSX
So what would be the best rear end. Not gear, I am talking about Posi. Will the SLP $99 be fine or are the $500 from powertrax and other companies better. What are the differences?
1990 RS 305 TBI T-5
180* stat
1990 RS 305 TBI T-5
180* stat
From my bench racing experience, I'd have to say that a powertrax locker is preferrable. Posis aren't as reliable, can't be installed in your driveway, and will still sometimes act like a one-legger.
Lockers, on the other hand have come a long way from their beginning. They engage way smoother, and when engaged, the rear axles are locked (duh).
Powertrax is a little more expensive, but you can make up most of that extra cost by installing it yourself, which is very possible.
No guts, no glory.
No guts, no glory.
It depends on what you want your car to do. If you want a dragster, a locker is best, but if you want to carve some canyons, a locker is definatly not a good idea. There are also manual lockers that will let your rear be fully open of fully locked. An OX locker is cable actuated, an ARB is air actuated. From my friends bad experieance I'd stay away from an ARB.
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
i say 9 responses isnt that bad, repost on another board linking to here if you would like. request from the original poster of the thread will get it moved.
