Fuel Pressure -- How much is too much?
Old Sep 18, 2001 | 07:05 PM
Stoopalini's Avatar
I've been having some performance problems lately, and after discussing it with a few knowledgeable people, we decided that maybe my fuel pressure was too high.
I've got a '92 RS (see sig for mods). The adjustable fuel regulator was allowing 13 psi of fuel pressure at it's lowest setting, and we thought this may be a problem.
I swapped it out for the stock one, which brought the pressure down to 11.5 psi, and
it seems to be running better. I won't really know until I drive it for a few days though.
Is 13 psi too much fuel pressure? I have an Air/Fuel Mixture gauge in the cab, and it did lean out the mixture, but just a very little bit. It is still running on the rich side.
Thanks for any advice,
Thomas.
1992 RS Camaro - Red
305-TBI/5 Speed Manual- 3.08 geared rear
1.6 Roller Rockers / Adjustable Fuel Regulator with high flow pump / Open Air K&N Filter / TBI Spacer / ADS Super Chip & custom burned Off-Road Only chip / MSD ignition
Headers - 3" Cat'Back - Flow Master - dual chrome tips
Adjustable Coni shocks & struts & 16" factory wheels
Old Sep 18, 2001 | 09:20 PM
NJ SPEEDER's Avatar
fuel pressure should only be adjusted as a stop gap to help keep proper air/fuel ratio if you don't have a custom chip.
therefore, any adjustment you make to the fuel pressure should be made only if the need is seen in the engine. adjusting the pressure just because you can has caused more probs for people than it has solved.
the injectors are rated to flow properly up to 13psi, and i can tell you from past mistakes that at 15psi they just shoot gas all over the place and make a big ineffective mess.
later
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Sep 18, 2001 | 09:29 PM
Stoopalini's Avatar
So, you're saying I should just keep it at stock; but 13 psi is still within the injector's specs.
If I got injector's from a 350's TBI unit, would I then be able to put the adjustable regulator back on and possibly up the pressure above 13 psi?
Right now I am running the custom track chip. I don't know the param's of it, but I could find out if it makes a difference?
Thanks for the info,
Thomas.
[This message has been edited by Stoopalini (edited September 18, 2001).]
Old Sep 18, 2001 | 11:18 PM
bluegoose's Avatar
Car: Firebird
Engine: 383
Transmission: 700R4, lots of Mods
Let me see if I understand this.. If i put a fuel pressure gague inline with the supply side I dont want the pressure to be above 13 psi. I have adj fuel pressure so I adjust the pressure I should see increase in pressure and vice versa. Now is it safe to say that If i increase pressure I shall make the motor run rich and vice a versa. It seems to me that I cannot get the correct adjustment on my fuel/air meter.
Old Sep 19, 2001 | 10:35 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
<font face="Verdana, Arial" size="2">Originally posted by bluegoose:
Let me see if I understand this.. If i put a fuel pressure gague inline with the supply side I dont want the pressure to be above 13 psi.</font>
you dont want your pressure to be making you run rich all the time. depending on your engine. some engines need 15 psi. stock ones. keep it around 11, tops.
<font face="Verdana, Arial" size="2"> I have adj fuel pressure so I adjust the pressure I should see increase in pressure and vice versa. </font>
WHAT?! confusing sentance. if you adjust pressure up, then you should see pressure go up. correct. is that what you were asking?
<font face="Verdana, Arial" size="2">Now is it safe to say that If i increase pressure I shall make the motor run rich and vice a versa. It seems to me that I cannot get the correct adjustment on my fuel/air meter.</font>
if you get your air fuel meter close enough, your computer will eventually take care of the rest. just get it as close as you can, and you mixture is going to change as you drive, you dont want 14.7:1 at wot, etc.. what are the specs of your air fuel ratio? do you know how lean you are when it reads lean? WOT a/f should be near 11.7:1 or 12 something to 1
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
