Water temp. gauge
Water temp. gauge
I need to know where to hook up an after market water temp. gauge. I know the heads, but where exactly. I hear many different places, but what is the best place.
1988 305 TBI camaro. Flowmaster exhaust, K&N air filter, complete IROC-Z makeover (stripes, ground effects, interior...etc), Kenwood c.d. player, Sony Xplod 6x9's, Blaupunkt 3 1/2's.
Car: 91 Red Sled
Are you going to disable the stock temp guage or should I ask do you even care about the stock guage working? If not, just install the sending unit into the stock temp guage sending unit hole. It's on the drivers side head imbetween the 1 and 3. You'll see the stock unit has a thumb pin look to it.
Other places to install the sending unit could be on the intake manifold (if it's an aftermarket unit). The stock intake doesn't have any extra provisions, just one for the CTS (ecm temp sensor). Hope this helps.
, Jon (350 TBI!)
91 Red My website
, Jon (350 TBI!)
91 Red My website
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Easiest way to add an aftermarket water temp gauge to the motor,without disturbing anything else, is to get a thermostat housing with a 1/2"NPT threaded hole in the top and add it there.Originally these are for a heater valve and the water temp you'll be looking at will be on it's way out of the motor when the thermostat is open.I ran one like this for years and it works well and is easy to install. Only drawback is of course the appearance.
1992 RS,5 Speed,T-Tops,Eibach Springs(cut), KYB's, Lakewood Trailing Arms and Adjustable Panhard Bar,Posi Disc Rear,3.73 Gears,Summit Rearend Support Cover,
Del-A-Lum Bushings,300 HP Crate Motor,Crane Comp-U-Cam,Edelbrock TBI Intake, Turbo City Ported Throttle Body and Adjustable Fuel Pressure Regulator,Open Element
Air Cleaner, Ground Control Strut Tower Brace and Caster/Camber Adjusters,SLP 1-5/8" Headers,Flowmaster 3" American Thunder Exhaust,3" Cat,Centerforce Dual
Friction Clutch,Hayes Billet Flywheel,B&M Power Steering Cooler,Big Thumpin' Stereo.
Hotrodboba400
Dec 10, 2019 07:07 PM
codeysabatini
Nov 10, 2015 04:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
