Dont hit me..
Old Apr 16, 2007 | 01:04 PM
The White Knight's Avatar
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Transmission: 200C 3 Speed
Axle/Gears: 2.93 Open Diff
Dont hit me..
I know this has been beaten to death, but I cannot find this info..
If I pull of the vaccuum line on the side of the EGR and plug it, and I still get the hesitation on light throttle acceleration, does that mean that its the solidnoid? What if I unplug the solinoid and leave the egr vac. port on?
(gettin code 32 when on hwy for about 20 min, and have light throttle bog and hesitation, which is fine at WOT)
Any other way to test either?
Old Apr 16, 2007 | 07:31 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: Dont hit me..
Stinger
Vacuum switch is used to activate EGR valve by applying vacuum to it. You may have a leaky switch - disconnect and plug on the supply side of the EGR switch. Code 32 is a result of ECM performing a self check during highway cruise by cycling EGR control valve and monitoring MAP sensor readings. I think I've mentioned this in prior posting. Look for other problems - vacuum leaks, not enogh fuel presure, etc.
//RF
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
apie2546
Oct 16, 2016 02:24 PM
RS Reaper
Sep 27, 2015 07:04 PM
Twinn Engines
Sep 25, 2015 06:27 AM
