lt1 cam specs
Car: 89 Formula
lt1 cam specs
Im thinking of putting a lt1 cam in my 91 camaro. I have checked the board and everyone seems to have alot of luck with them. I was just wondering what the specs are, lift, duration, etc. Also what is the rpm range on them?
there are several different grinds. The best of the grinds are the cams from the 96-97 cars. You can pick them up used for well under $100 on any of the fourth gen sites.
the grind for that cam is
int 201* @.050"
exh 208* @.050"
lift is
int .447
exh .459
with 1.5:1
hope this helps
int 201* @.050"
exh 208* @.050"
lift is
int .447
exh .459
with 1.5:1
hope this helps
gixxer92
Sep 1, 2015 04:32 PM
