rich or lean??????
Old Oct 1, 2001 | 05:26 PM
91firebirdfosho's Avatar
Car: 1991 firebird formula
Engine: 383
Transmission: th350
Axle/Gears: 3:73 posi
rich or lean??????
i have a 305 tbi and i put pace setter headers on a bigger cam not too big and edelbrock intake now it has no torque and has no real power i went from a roller cam to a flat tappet cam do i need a new chip or are these messing up my fuel settings
Old Oct 2, 2001 | 12:45 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
The best way to know is with a scan tool. But since you don't have one, pull the plugs and see for yourself. You really don't want us to guess do you? The diagnosis with a scan tool will also answer your question of needing a custom chip burned for those mod's. We checked my engine last week. LT1 cam swap, SLP 1-5/8 headers, 3" exhaust, Random technologies cat, S&B open air filter and the vAFPR. We found the stock chip was still handling the mod's fine. We did burn a new chip to tweak it a bit, add a bit of timing at WOT and remove the speed limiter. But it was running strong and really pulling mid-high rpm's great with the stock chip. Bottom line; borrow a scan tool.
90 RS Convertible
Owner: Top-Down Solutions
(626)369-0040
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
F-body-fan
Jan 12, 2023 01:49 PM
Mark_ZZ3
May 24, 2018 01:02 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
Luigytico09
Oct 1, 2015 08:46 AM
Jk_Under
Sep 8, 2015 08:13 AM
