This any cood from edelbrock?
Old Oct 2, 2001 | 01:57 PM
92Camaro305TBI's Avatar
This any GOOD(sorry about the spelling)
I was looking around the site and notices this....
Performer T.B.I. (EGR) #3704
Injector Recommendations:
Use stock Throttle Body Injection unit
Installation Notes: Recommended intake gasket: GM #10159409. Manifold Height: A-3.70", B-5.10", see manifold selection page, .250" taller than stock
PERFORMER-PLUS CAMSHAFT KIT
Designed for use with Edelbrock Performer T.B.I. manifold #3704 on 1987 & later 305 and 350 c.i.d. S/B Chevy Throttle Body Injected V8s. 50- state street legal when used as part of the 5.7L Total Power Package (intake manifold #3704, cylinder heads #6085 and computer chip). See Chevy cam page for cam specs.
[This message has been edited by 92Camaro305TBI (edited October 02, 2001).]
Old Oct 2, 2001 | 02:36 PM
NTChrist's Avatar
Well, I can't say from direct experience, but I've heard a lot of bad things about the Edelbrock manifold. Generally, the complaint is that there is little difference between it and the stock manifold. Although, this isn't a constant. Some people like it.
The cam is a little more definite. The cam is bad. It's a hydraulic, flat lifter type cam. You'd lose the hydraulic roller-lifters that our engines come with, and the horsepower associated with the loss of friction. It's also too small to be useful on a modified engine, and overpriced at that. If I was looking for a junk cam to throw in a block, I'd go with a Summit or PAW house cam.
That's Edelbrock's problem. They usually assume that the only modification you're going to make, is the one you buy from them. This isn't so true if you're buying the higher end Victor or Torker parts, but there are none that are a direct replacement for our cars.
No guts, no glory.
Old Oct 2, 2001 | 02:52 PM
Thanks....
Old Oct 2, 2001 | 04:30 PM
DM91RS's Avatar
Car: 91 RS
Read NJ Speeders post's. He's running that intake and does very well with it. He's also going with an LT1 cam as many people are for the LO3. It is a direct replacement for the stock cam. Just make sure that you valve springs are up to the task and that the pin on the end of the cam does not stick out any farther than the stock one does. Also they can be purchased used for a low price. Used roller cams are ok to use.
91 RS 5.0 TBI....Edel. TES headers .. 3" exhaust ...Dynomax muffler...5spd... 3.08...underdrive pulleys...cold air K&N flat bottom breather...strut tower brace...6-point rollbar...sub-frame connectors...Koni shocks and struts...16" Black GTA wheels...Autometer guages...custom chip...Grant steering wheel...a/c delete...smog delete...rear seat delete...ultimate TBI mods...afpr...36mm front and 25mm rear swaybars with poly bushings...
Old Oct 2, 2001 | 04:48 PM
NJ SPEEDER's Avatar
i really like this manifold. if you plan on keeping your combo mild or only going as far as the LT1 cam it will work well. if in the long run you do get a cam the holley intake and TB will get you more top end power because of greater manifold volume. i don't think the difference is huge or anything though.
the best part about edelbrock is that their parts are always a true bolt on. every bolt boss and vacuum port is right where it belongs from the factory, i can't say that for anything holley has ever made.
later
tim
91 Camaro RS-LO3,Auto
New Times Coming Soon!
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Oct 2, 2001 | 06:00 PM
DM91RS's Avatar
Car: 91 RS
Yep, Edelbrock intake and headers gave me no problems at any time and I have had those headers since 1995 on 3 different engines. Sure would like to get some coated ones though!
Old Oct 2, 2001 | 07:37 PM
fast_broker's Avatar
That cam is very mellow and nothing special. better off with a cheapo 204/214deg .420"/.442" lift cam from Summit for $69ish, as suggested. I used the 3702 in a 350cid and got like 240hp, btw. Not a bad cam, just VERY mellow and better for putters/trucks/emissions probs.
Pac J
May 17, 2020 10:44 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
