Is there any kind of fuel gauge that I can put on a TBI?
Old Oct 1, 2001 | 07:39 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
You know the adjustable gauge under the hood.
89 Formula Firebird
Red with T-tops
5.0 305 FI
Soon to be a 400sb.
Old Oct 2, 2001 | 09:16 AM
scauffiel's Avatar
An adjustable "gauge?" Do you mean an adjustable fuel pressure regulator? Or maybe a fuel pressure gauge? Normally pressure gauges aren't adjustable, per se. I've got info on my site about modifying your regulator to make it adjustable AND a couple of pix of my fuel pressure gauge install.
Not real clear on your question...
Steve
Steve's Trans Am Temple
Old Oct 3, 2001 | 09:12 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
if you are looking for a guage, it is definitely possible..i put a summit fuel pressure gauge on my car, and it cost me a total of like 15 or 20 bucks. pretty cheap if you ask me. i dont have any pics though (yet). basically i switched form teh steel lines from the area of the power steering pump to the throttle body with rubber lines. that way i just plumbed it right into a 3/8" rubber fuel line. worked awesome, and looks a hell of a lot better than the steel lines that didnt really fit well to begin with.
-brian
1991 Camaro RS - ultra blue metallic, t-tops
GMPP 350 HO crate engine - 454 TBI, MSD ignition, SLP exhaust, everything is new
700R4 - 2,400 stall converter, vette servo, shift kit
z28boy.cz28.com
Central New York F-Body Association
z28boy@twcny.rr.com AIM - "Z28 Boy"
1998 Pontiac Grand Prix GT - 2 door, black
Old Oct 3, 2001 | 09:24 AM
fast_broker's Avatar
I "teed-in" an Auto Meter isolated (ie, no fuel in cab, only antifreeze) in-cab 15psi fuel pressure gage. In-dash, sweet...
Old Oct 4, 2001 | 12:03 AM
i roc k's Avatar
fast_broker any pictures???
Old Oct 4, 2001 | 12:17 AM
JPrevost's Avatar
Car: 91 Red Sled
yeah, how much did that cost (parts not labor) for the remote mount fp guage?
, Jon (350 TBI!)
91 Red My website
Old Oct 4, 2001 | 08:00 AM
It's in my Jeep's dash, not Thirdgen, so can't help you with the "labor/parts" for your cars. Jeep dashes are VERY easy to work on, as any other Jeep owner knows. The gage is like $85 I think from Summit and worth every penney. Comes totally complete with a braided stainless isolator line full of water and antifreeze ready-to-go, and VERY nice looking. I have the FP gage along with Oil Pressure, Volts, H2O Temp, Fuel Level, Vac Level, Tranny Temp, Engine Oil Temp. I basically reoved the OEM plastic plate/gage pod, cut out a bunch of it, cut a flat 1/8" thick aluminum plate and aluminum rivited it to the OEM plastic, cut the gage holes in the aluminum and mounted the aluminum faced AutoMeters inthere, along with the Edelbrock AirFuel Meter thingy and a switch to turn it off, if I want.
[This message has been edited by fast_broker (edited October 04, 2001).]
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
MustangBeater20
Oct 29, 2022 09:20 PM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
