haynes manuals
Old Apr 22, 2007 | 06:47 PM
ad356's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Axle/Gears: 3.23 lsd swap
haynes manuals
my camaro haynes manual doesnt include a TBI engine management wirring diagram. im not happy/ it has to be one of the most common engines in our cars. im getting very pissed off. no matter what i do i cannot get my car to run properly. i replaced the altenator today. still no results. i have literly thrown the kitchen sink at this engine. replaced fuel pressure regulator, collant temp sensor, altenator, igition coil, cap, rotor, plugs, wires, EGR(had to be replaced anyways), fuel pressure regulator, 02 sensor, and map sensor. what ever is wrong is with out a doubt electrical. it took me a while to figure that out. something is pulling current away from the iginition coil (im guessing) when the cooling fan runs. it first i didnt know it was tied into the cooling fan. i have disconnected the block fan switch and i turn the fan on using the climate control unit A/C on. in what way is the iginition coil tied into the cooling fan, ECM, or igintion module? does this sound like power is being pulled from the ecm, coil, or igition control module? tach will sometimes drop to zero and will bounce all over the place. it doesnt even do it all of the time. car will run very poorly when this happens. if i would guess i could say something is grounding out the coil power source. i wish i could figure this out on my own. if you guys dont have any advice on how to fix this or where the problem might be im going to take it into a shop and spend $$$ fixing this. i wish i could figure it out on my own. if i send it in somewhere to have it looked at i havent learned anything except how to hand over hard earned money. i will spend the money if i have to but would rather fix it myself.
anyways dont buy a haynes manual if you have a TBI car. it covers TPI and v6's quite well but missing a wirring diagram for the TBI is something big in my opinion.
Old Apr 22, 2007 | 09:54 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: haynes manuals
The chiltons manuals have, or used to have, the complete reprint of the factory f-body wiring diagrams. Granted its not in color like the original, but it still serves its purpose.
Old Apr 22, 2007 | 10:27 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Transmission: manual
Re: haynes manuals
i beleive the manuals he is using consider the tbi to be efi or ported fuel injection. i have a chiltons and it says NOTHING about tbi just efi multi port and tpi and carb. so they refer to tbi as efi...i think
Falcon50
Aug 22, 2020 03:26 PM
Fireslash
Apr 11, 2016 06:43 PM
bjpotter
Oct 4, 2015 07:48 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
tattmann
Sep 27, 2015 05:20 PM
