Compression Test Question?
Old Oct 9, 2001 | 11:21 AM
saus89's Avatar
I own an 89 Firebird with a 305. I was wondering what the compression should read in pounds per square inch. I performed the test and came up with 150 psi per cylinder and I was wondering if this is what it is supposed to be, or is it low. Also how long are you suppossed to crank the motor when you are performing the test?
Old Oct 9, 2001 | 12:32 PM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
as far as cranking compression goes, it can vary from engine to engine, the key to running a compression test is to see if any of the cylinders are below 10% of the 'normal' cylinders, that is, if they all are 150psi +- 15 psi of each other, then the engine is in good shape as far as compression. 150 lbs sounds about right for a 305 engine, with reasonable mileage. If any of the cylinders are far below what the rest read(say, only 70 psi), you can be assured that there is either a bad valve, weak or broken ring(s), or significant cylinder wall scoring. You should only have to crank the engine to get a solid reading, a few revolutions should be fine. As a note, you can tell if the problem is ring/cylinder related, or valve related by performing the test again after squirting some oil into the cylinder. A cylinder that has valve problems will read the same number, whereas an engine w/ mild ring weakness or scoring will jump up in pressure. Hope this helps.
Old Oct 9, 2001 | 04:42 PM
JPrevost's Avatar
Car: 91 Red Sled
That is a good point about the oil compression trick. My friend just bought an old jeep. We noticed that with the oil the compression was up again so now we know it's the piston ring or block .
, Jon (350 TBI!)
91 Red My website
Old Oct 14, 2001 | 01:01 PM
Vader's Avatar
Saus,
Test the engine warm if possible. Remove all the plugs. Charge the battery fully. Hold the throttle open fully. Crank the engine at least four full cycles (eight revolutions). Your compression should be at about the peak reading, and additional cranking probably won't get any more pressure built in the gauge.
150 PSIG is pretty good for a flat-topped piston 305, especially if you tested it cold with the throttle closed.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
beastin91rs
Oct 9, 2015 07:38 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
