popping noise from intake
Car: 89 Camaro RS
Engine: LM7
i changed my plugs this weekend and now i've got a popping noise when i rev the motor or get on it hard when driving. timeing and firing order are correct. Anyone have any ideas? '89 camaro 350 tbi, 5spd.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: popping noise from intake
Assuming no ignition issues and the timing is correct, it sounds like a lean issue. when the motor goes lean, itll pop out the intake. Does it still have the stock pump? Any mods?
Car: 89 Camaro RS
Engine: LM7
still have the stock pump, filter changed a few months ago. only mods are a chip and exhuast. whats a good way to check to see if its lean?
Car: 88 Camaro SC
Engine: SFI'd 350
Easiest thing may be to check the fuel pressure and make sure it still delivers around 12 PSI. If its unsteady or the pressure drops when the motor is under load, then its time for a new pump.
Car: 89 Camaro RS
Engine: LM7
changed my plugs out again. all of them were clean except #7 which was black. bad cam lobe or bent push rod maybe? about to chk. my fuel pressure, just need to figure out how to hook up the gauge.
Car: 1992 Jeep Wrangler + a few more car
Engine: Gm 5.7 T.B.I with 1227747 ECM
Transmission: 700r4 DIY built
Axle/Gears: Ford 8.8/D30- 4:10 and lockers
This same thing happened to me tonite. I changed plugs and wires (for really good ones) and under wot its popping out the intake.. intresting
90 350 TBI
90 350 TBI
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Also, test your wires, use a multimeter and check the resistance from end to end. Post your results.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
