HELP! Burnt connector- what is it?
Old Mar 7, 2010 | 04:43 PM
t/adreams's Avatar
Car: '91 Trans Am
Engine: 350 Blueprint Engines Cruiser
Transmission: TKX 5 speed
Axle/Gears: 3:42
Hey guys,
I have a burnt wire/connector in my wiring harness. The car is an '88 TBI. It doesn't seem to affect anything unless it grounds out. If/when it does, the engine sputters.
As for location, it branches off the main harness briefly, into that connector, back out and and I'm fairly certain it leads into a smaller loom (pictured). I don't know what that loom does either. The connector itself is on the pass. side, just behind the transmission fluid dip stick.
Pictures commence!
Connector
Connector again
The loom that the wire runs into and comes out at. The loom goes up and around the HVAC into the branches you see here.
Another angle of the connector.
Thanks for the help!
Old Mar 7, 2010 | 04:57 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: HELP! Burnt connector- what is it?
looks like the blower motor power
Old Mar 8, 2010 | 12:58 PM
t/adreams's Avatar
Car: '91 Trans Am
Axle/Gears: 3:42
Thanks! I was able to confirm that today. I'll be removing the connector and splicing the wires together soon.
Old Mar 8, 2010 | 09:16 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
That's exactly what I did with mine. It was meant as a temporary fix until I replace the connector, it's still just spliced together after about 2 years
Glowsock
Jul 24, 2025 03:15 PM
Elephantismo
Feb 13, 2019 12:51 AM
Bigold4x4
Sep 28, 2015 05:21 PM
gta892000
Sep 16, 2015 12:37 AM
someone972
Aug 30, 2015 12:52 AM
