350 injectors
Old Oct 21, 2001 | 04:12 AM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
350 injectors
what makes and models would be a good place to start looking in junkyard for 350 injectors? the reason why is because I am running a 350 engine with 305 injectors. The engine was swapped before I purchased. Also, is thier a prom i could snag off the same auto that I get the injectors from? my idea is maybe a caprice classic, or suburban....what years? Any help is appreciated....
<font face="Verdana, Arial" size="2">I have experience......unfortunatly its a result of bad judgement......</font>
click below to check out the new Formula Source....
www.theformulasource.com
or click below to check out my Formula350.......
www.formula350.com
or click below to email me
webmaster@theformulasource.com
[This message has been edited by formula90 (edited October 21, 2001).]
Old Oct 21, 2001 | 09:18 AM
gt auto's Avatar
hey, I have the same ???? Does this effect your fule milage??
Old Oct 21, 2001 | 10:09 AM
Brent's Avatar
89-90 Caprices will have the injectors you want and a prom you can run. The prom will probably leave much to be desired because it is configured for the 200HP LO5.
A truck prom will not work in your ECM.
Old Oct 21, 2001 | 02:26 PM
JPrevost's Avatar
Car: 91 Red Sled
you want 350 injectors and if you have a worked 350 with more hp than ~220 you'll want to play with fuel pressure!
The good thing about the 7747 (truck ecm) and the 8746 (your ecm) is that you can swap them in and out. The 7747 was usually with a 350 so that might be a good idea. Or you could e-mail me and I can send out a caprice 350 eprom for your 8746.
, Jon (350 TBI!)
91 Red My website
Old Oct 21, 2001 | 06:10 PM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
so in other words....the ecm will swap, but the proms wont....?
www.formula350.com
Old Oct 21, 2001 | 06:12 PM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
also..wouldnt i just be able to grab a ecm that used a tbi system? so if i did use a truck ecm...wouldnt that truck also have to be using tbi? were the ecm's designed around the fuel intake?
www.formula350.com
MustangBeater20
Oct 29, 2022 09:20 PM
bamaboy0323
Sep 3, 2015 06:07 AM
xxx3man`
Aug 28, 2015 02:21 PM
Keith5
Aug 27, 2015 04:37 PM
Eric-86sc
Aug 24, 2015 09:01 PM
