bad gas milage help!
Old Oct 19, 2001 | 06:52 PM
gt auto's Avatar
Hey I have a 91 Camaro rs It came with a 305 from the factory. The guy I got it from had a 350 put in. They used the 305 intake, TB, I think everything but the block and heads are from the 305. Anyway it gets really bad gas milage. I have a firebird that gets twice the milage then the camaro. It does send a code 24 vss??? what where and how??
HELP!!!!!!!!!!
Old Oct 20, 2001 | 06:26 PM
Trent257's Avatar
i dont know about your gas milage problem, bad plugs??
but heres wut my manual says for code 24
Vehicle Speed Sensor
Poor electrical connection, open or short in circuit, defective VSS; defective ECM, A fault in this circuit should be indicated only when the vehicle is in motion, disreguard code 24 if it is set when the drive wheels are not turning
Trent
---Car---
89 Firebird/305 L03 TBI A4/t-tops
Open Element Edelbrock Aircleaner w/ K&N air filter/Summit Chrome Valve Covers
---Stero---
Pioneer DEH-P730 Premium
Infinity 2way 4652 4x6's/Pioneer 4way ts-a6985 6x9's
profile cl640 110x4
----Comming in a few days----
Edelbrock TES headers 3" out/flowmaster American thunder 3" exaust/Catco HighFlow catco cat
Old Oct 20, 2001 | 06:35 PM
JPrevost's Avatar
Car: 91 Red Sled
First off, if you have an auto then the VSS is very important to gas milage. You're torque converter won't be locking up....ever. This isn't good for gas milage. Do you know the gears you have in the camaro? That could also be a problem.
I want you to do something for me, check to make sure you've got the 350 injectors on that 350. The TB is the same as the 305 but the injectors are different.
If you pop off the injector tops you should see a color on each of the injectors.
If they're the stock injectors you'll see green and white. If it's from a 350 you should see black and orange.
Here is the link:
http://diy-efi.org/gmecm/component_i...injectors.html
Now if you DO have a 350 and you're running 305 injectors you're starving the engine. The ecm will make up for it but you won't get very good gas milage.
, Jon (350 TBI!)
91 Red My website
Old Oct 20, 2001 | 08:17 PM
gt auto's Avatar
Not sure on the gears. The injectors are from the 305. Do I just get a set for a 350 or would I have to change the ecm also?? About the vss What should I check fires?
Thanks!!!
Old Oct 23, 2001 | 01:54 PM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
[quote]Anyway it gets really bad gas milage.[quote] My 305 gets 17city/25 highway with the air on if I drive it normally.
"91" RS, 305 tbi, 5spd, Slp Y-pipe, Random tech Cat, Flowmaster crossflow, Ultimate tbi mods, Edelbrock open element with 3" K&N, Taylor Spiro Pro wires, Redline water wetter, 180* thermostat.
Old Oct 23, 2001 | 02:00 PM
fast_broker's Avatar
GTauto, you can get by with an increase in Fuel Pressure, if you like. GO to the Tech Articles on the main page of this site and look for AFPR (adjustable fuel pressure regulator) artice and you'll get the gist...
chazman
Aug 28, 2018 03:25 PM
Jae992
Aug 27, 2015 09:07 AM
chazman
Aug 22, 2015 02:01 PM
Bradsaundry
Aug 12, 2015 12:34 AM
