Removing Air Conditioning
Old Oct 22, 2001 | 04:43 PM
Trent257's Avatar
is it possible to remove my air conditioning, but keep it in tact, so one day i might be able to sell the car with it, also how do i remove the heater valve, i tryed a search and still am confussed
Trent
---Car---
89 Firebird/305 L03 TBI A4/t-tops
Open Element Edelbrock Aircleaner w/ K&N air filter/Summit Chrome Valve Covers
---Stero---
Pioneer DEH-P730 Premium
Infinity 2way 4652 4x6's/Pioneer 4way ts-a6985 6x9's
profile cl640 110x4
----Comming in a few days----
Edelbrock TES headers 3" out/flowmaster American thunder 3" exaust/Catco HighFlow catco cat
Old Oct 22, 2001 | 07:06 PM
89RS355's Avatar
Yes, you can get the air conditioning eliminator and save the compressor. When you want to add it back on, you will need to replace the reciever drier, bolt the compressor up and take it to a shop to pull a vacuum on it and re-charge it to find any additional leaks. I have done it, and it was no big deal.
As for the heater valve, do you mean the control that divert coolant to the heater core? Just take the hoses off the heater core tubes against the fire wall and get a plug to thread into that part of the manifold. Might want to take some compressed air and blow out one side of the heater core tubes (don't ask). If this is what you mean, this is would work.
Jerry
1989 Lt. Blue RS 5-speed
355 crate motor, Compucam 2040,
PST Front suspension,
Hotchkis rear suspension,
EDL T.E.S., 3" Flowmaster
Harwood cowl hood
1994 Black Z28 6-speed
Nothing major, but FUN!
Old Oct 22, 2001 | 10:57 PM
Tas's Avatar
Tas
search for "heater valve delete" there should be lots of posts to look through. If there isn't, try "heater valve"
Old Oct 23, 2001 | 05:09 PM
JPrevost's Avatar
Car: 91 Red Sled
Heater valve delete: I'm doing it, got all the parts and now just need to drain the coolant so I can change the thermo and upper radiator hose.
You'll need 3/4 and 5/8 heater hose, get about 3 feet of each. You're going to want to run the 3/4 to the waterpump and the 5/8 to the intake manifold.
You'll need the barbed fittings. Go with brass from homedepot. The waterpump and intake (if standard) should be 1/2" and standard compression thread, NOT garden hose!
I had to do some nifty adapting because I couldn't find the 3/4" barb to 1/2" so I went the garden hose route just for the barb and then adapted it to the 1/2" compression thread. Lowes and Home Depot only have one little tray item that has a 3/4" barb with compression thread , it's usually empty.
I would also recommend using the teflon tape. Double layers and it'll work great and last forever. I like the teflon tape because it's cheap, easy, clean, and works everytime. Everything on my new engine is teflon taped .
I'll have pictures up on my website when I get the chance, damn school work, today I just found out they ADDED 2 more physics labs to the end of the quarter!!! AAAAHHHHHH
, Jon (350 TBI!)
91 Red My website
Old Oct 23, 2001 | 09:31 PM
Trent257's Avatar
ok thanks, question about the air conditioning, how do i take out the big black part, that sits on the firewall, i got the rest out, i took 3 screws off that, where it the other one(s)
Trent
---Car---
---Stero---
profile cl640 110x4
Old Oct 24, 2001 | 03:33 PM
Trent257's Avatar
anyone
Trent
---Car---
---Stero---
profile cl640 110x4
Old Oct 24, 2001 | 07:01 PM
DM91RS's Avatar
Car: 91 RS
If your question is how do you get to the screws that you can't see under the hood, they are under that mess that's under the dash. Fun time for sure. Do you have a non-a/c heater box or are you going to delete the heat too?
91 RS 5.0 TBI....LT4 cam....Edelbrock headers....3"Dynomax exhaust....5spd.... 3.08.....Ultimate tbi....afpr...ZR 255-50's...Koni's
Old Oct 24, 2001 | 09:46 PM
Trent257's Avatar
im going to try to leave the heat if possible, but if i cant, its gone, ill just wear a coat, you say i have to get at it form under the dash inside on the passanger side?
Trent
---Car---
---Stero---
profile cl640 110x4
Vintageracer
Jan 10, 2020 05:33 PM
theurge
Aug 21, 2015 12:46 PM
jackhammer
Aug 15, 2015 10:04 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
