KIND OF A WIERD TOPIC BUT HEAT!!!!
Old Oct 26, 2001 | 01:57 PM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
the problem is im here in chicago and its really cold and windy and yesterday i decided to try the heat for the first time , so i let the engine run until the temp guage was about 200 degrees and turned on the heat, except the air that comes out is mostly cold... not good for chiago winters.. i dont think its the heater core, no anti-freeze on passinger side floor and i do hear the blower motor go on and it does blow out air so i dont think its that either.. I need some ideas to check on so i dont freeze all winter..
thanks
91 camaro RS
- 305 TBI
Mods: Performer TBI intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter, b+m trans cooler, white guage faces, megashifter..
next month: spohn LCA's and panhard rod, BMR relocation brackets,posi 323 , lt1 cam and new valve springs
Old Oct 26, 2001 | 02:02 PM
Tas's Avatar
Tas
the heater valve might be stuck. there is a vaccume line that goes to it that I think turns it on so coolant can go to your heater.
-Tas
'89 Formula WS.6
Old Oct 26, 2001 | 03:33 PM
bbtaz97's Avatar
Car: 91 RS
GREAT IDEA.. I DIDNT THINK OF THAT.. I WILL CHECK THAT TONIGHT..
ANY OTHER IDEAS??
Old Oct 26, 2001 | 04:46 PM
Fish89's Avatar
Car: 89 Camaro
Engine: 97 LT1
Axle/Gears: 323 Posi
Yo BBTAZ 97. I live in Lisle right by you. But yes I agree If the heater core is fine then it might be the heater valve.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
drumstixer
Sep 29, 2015 03:02 PM
lanceflame44
Sep 25, 2015 12:28 PM
