Cam swap; Which Valve Springs do I buy??
I am swapping in a 95Z LT1 cam, with 1.6:1 Roller Rockers. I need a set of springs that will handle revving to 6 grand, and support the lift... I have no idea what size these are, can anyone help??
Thanks,
Clint
1991 Firebird Bandit II Edition
Flowmaster 80 series muffler
no Air/Cat, straight pipe
no smog pump/pulley
K&N Open Element cleaner
Ultimate TBI Mods (port/polish, AFPR)
1" TBI Spacer .25" Injector Spacer
Homemade Subframe Connectors
GM Wonderbar
Waiting to install;
95 Z28 LT1 Camshaft
1.6:1 RR
Bryco double roller timing set
LT4 valve springs
36mm front, 24mm rear anti-sway bars
Polyurethane everything!
MacEwan Motorsports Silver-Faced guages
lead pedal foot
. See my project rocket turtle @
http://oursportscars.homestead.com/firebird.html
Member of Tidewater Trans Am Club
www.ttac.net
Thanks,
Clint
no smog pump/pulley
GM Wonderbar
Waiting to install;
95 Z28 LT1 Camshaft
1.6:1 RR
LT4 valve springs
lead pedal foot
. See my project rocket turtle @ http://oursportscars.homestead.com/firebird.html
www.ttac.net
This isn't exactly what I wanted to show you (there was a thread with that info plus more), but maybe you can ask him if you can use those and then report the good news back to us. https://www.thirdgen.org/messgboard/...ML/004968.html
-Tas
'89 Formula WS.6
-Tas
'89 Formula WS.6
1988iroc350tpi
Aug 14, 2015 07:52 PM
