Airflow Enhancer
Old Oct 31, 2001 | 02:59 PM
RSRagtop's Avatar
Airflow Enhancer
I keep seeing these " airflow enhancers " that replace the neck of the stock air cleaner. They always say that they only fit cars after modifications. So how do you have to modify them so they'll work. I'm worried about hood clearance because I have the taller truck lid and filter, and I plan to add the taller Performer TBI intake and a nitrous plate . I want my car to be a sleeper so a big cowl induction hood is not an option. I do have the Z28 twin blister hood on it though, does that help clearance?
Old Oct 31, 2001 | 07:19 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Umm...no. The Z28 Power-Blisters just bolt onto a normal flat hood.
Old Oct 31, 2001 | 08:18 PM
Kyle F's Avatar
Yea hood clearence is a problem for these cars. If you dont want a Cowl hood you are about out of options. Jprevost has had to cut some of the bracing out from underneath the hood of his because of this.
I dont think a taller manifold and Nitrous plate will fit even witht he stock airfilter housing.
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
Old Oct 31, 2001 | 11:14 PM
JPrevost's Avatar
Car: 91 Red Sled
The performer has a better carb level (lower in front), this helps keep the 14x3 air cleaners under the hood. The RPM intake which I have is taller in the front and slightly more so in the rear. This makes the front of my air cleaner more of a clearance problem than the rear. I gotta work on this some more but I think I can get it to work.
chazman
Aug 28, 2018 03:25 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
Nervous2
Oct 8, 2015 10:53 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
chazman
Aug 22, 2015 02:01 PM
