Raced this dude in a 383 TBI
Old Oct 31, 2001 | 09:42 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
So I was on my favorite racing street when some dude pulled up in a camaro. We raced and he was pretty fast. So I pulled over and popped our hoods and he had a 383 with the stock tbi bolted on top. He said he ran 104 mph at the track. Judging from how it ran I probably buy it. He had no programming and had no idea what he was talking about but the car ran well. What do you guys say to that? I thought he would have some serious leaning out issues but who knows?
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
Old Oct 31, 2001 | 10:27 AM
fast_broker's Avatar
Maybe he payed for the motor work... He's just the driver???
Or he has a mellow enough cam in the 383 with big enough injectors and a possible FP increase to make it run reasonably?
The low-rpm torque advantage (ie, off the line) of a 383 is tough to beat, even if it is a mellow 383.
[This message has been edited by fast_broker (edited October 31, 2001).]
Old Oct 31, 2001 | 11:29 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Without tuning it aint ****. He prolly just picked up a 383 from someone else (probably built to fit under a carb) and plunked his stock tbi on it. I'd imagine he's running his stock chip, too, if he was like you described him. It'd be nice to see someone build a real beast like that though
Chuck Kulchar
1991 RS
Open Element w/K&N
3" cat and Force II cat-back
Old Oct 31, 2001 | 11:56 AM
JPrevost's Avatar
Car: 91 Red Sled
excuse me while I clear my throat...cough~bull~cough~shi
I can't see how a 383 with even a mellow cam would run strong with a stock eprom. The only way he WOULDN'T be running lean is if he's got some major mods like a wideband o2 sensor and he needs at LEAST 350 injectors to get a 104 trap speed. Oh, maybe his car only weighs 2000lbs, then I can believe it.
I truely don't believe this is just a stock 305 TBI unit with a stock ecm/eprom on ANY 383.
I have to say, I'm glad to hear of a TBI system running strong.
Old Oct 31, 2001 | 12:14 PM
He didn't sa it was a stock "305" TBI, just that it was a stock TBI... Maybe a 350 unit: w/the big injectors? worked on by a PRO, if the guy didn't know what he was doing.??? I doubt an engine builder would just slap any old TBI on his new motor without making sure it would not run ok... At leas I wouldn't. Would you? I bet it pulls clean to 5000rpm, which is plenty to win a street race in a 383 with the right gears.
Old Oct 31, 2001 | 01:56 PM
ChevelleCLM's Avatar
Guys I must have just lucked out, cuz I have some mystery injectors. I do not know what they came out of or what they are, but my car pulls great up to 5700, and the motor just stops pulling about then. No fault of the injectors. My car did that with the beastly quadrajet carb I used to have. I have a stock throttle body, and a the 747 computer that I have burned a few chips for, but nothign serious as I do not have a scantool!!! which I need desperatly!!!
69 Chevelle 2dr hardtop blue, bench seats, 12 bolt w/3.73's muncie 4 speed. TBI w/custom harness and prom best 14.5@90
Old Oct 31, 2001 | 09:36 PM
Car: 1991 Firebird
Engine: 427 LSX
No really, I had a 305 TBI. He had a 305 car and tb top half. he asked me about getting a bigger TB. He said the car was lean at the top but still ran pretty well. Sounds like he just bolted some stuff together and it ran decent.
Old Nov 1, 2001 | 07:58 AM
I knew it would be lean up top BUT a 383 makes GOBS of torque down low... Makes you want a 383, eh?
Old Nov 1, 2001 | 09:28 PM
Car: 1991 Firebird
Engine: 427 LSX
no, makes me want a 406
Old Nov 1, 2001 | 09:47 PM
I guess I never thought about it but I bet you could, perhaps, bore and stroke a 502 crate motor for a reasonable price...
Old Nov 1, 2001 | 10:44 PM
Car: 1991 Firebird
Engine: 427 LSX
yes, and then you could bore and stroke that. your point is??
Old Nov 4, 2001 | 12:44 AM
IrocJT's Avatar
I would like to use a Cadillac 500.
Toss dual 670's on top of that! If you use heads from the earlier 472 (I think) you can get some where near 12:1 compression. They are supposed to be kick *** heads too.
1990 Iroc
Canadian Iroc (305 TBI)
-14x3 open element, K&N
-Accel: Coil, Wires, Cap&Rotor
-B&M stage 2 shift Kit
- 4 255/50/ZR16 BFGoodrich Comp TA's
-Hypertech chip, low temp thermostat and fan switch
-1.6 ratio roller rockers
-3" exuast: High flow cat, meanstreak muffler, dual 2.5" outlets
-Holley projection Manifold
-670 Holley TBI.
Old Nov 4, 2001 | 10:22 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
<font face="Verdana, Arial" size="2">Originally posted by GofasterFirebird:
</font>
A sleeper looks stock.
To glance at a TB and judge wiether it has 2" or 1.8" butterflies, takes a good eye. The injectors you can't tell.
And the chip in my car is *stock*.
104 with a TBI?.
I got 99.99 and that was it and I had alot of time tweaking mine. Cracking a 100 in a full weight car is doing something, in my book.
Old Nov 4, 2001 | 05:39 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
i say he paid for it all. i know too many people who have hot engines, and dont even know how to put a spark plug in it.
sad
Old Nov 5, 2001 | 07:55 AM
My hands are dirty, Mr. 383's hands are clean, I bet... I blew my spider gears in the OEM Dana 35C 3.07 "Winter" axle, again, this weekend... pisser./
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
Drone358
Dec 10, 2015 08:16 PM
84 TA NV
Sep 6, 2015 08:02 PM
Amillionoh7
Sep 5, 2015 11:44 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
