I have pics of the intake dilemma....
Old Nov 10, 2001 | 01:04 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Thanks for taking a look. HolleyEGRproblem.bmp you can see where the IAC wiould hit the EGR valve. Sorry to you dial-up guys, the pictures are .bmp's, I haven't reloaded PhotoShop to make them .jpg's. Please take a look anyway.
Thanks!
http://communities.msn.com/V8AstroCa...astromods.msnw
'92 Astro, GM crate 350, Holley Pro-Jection Intake, MSD 6AL, 3.42's, 2.5" exhaust, Flowmaster 40 2 chamber, B&M 2nd stage shift kit, 255 60 R15 tires on AR-727's, Polished & Bored TBI, Custom EPROM in progress
Old Nov 10, 2001 | 03:56 PM
JPrevost's Avatar
Car: 91 Red Sled
Yuck, I see what you mean (second page of pictures). I didn't know it was that bad.
Do you have an TB spacer? Do you have cowl hood? If yes, then just make a spacer for the TB OR scrap the egr all together and run without it. E-mail me if you want to know how to get rid of EGR.
Those seem to be the only easy options. I guess you could somehow relocated the EGR but that would just **** me off and waste time. That's just my opinion, I don't like EGR.
Old Nov 10, 2001 | 05:18 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
Next question. You know that I started all this bullsh!t because the manifold kept leaking out the front and rear seals.
What gasket sealer should I use? I've been using Ultra Black, but it seems like the oil is seeping right thru the stuff. Almost like it's "sweating" out.
I heard that Honda makes an RTV that is some crazy stuff. I also heard the same thing about "The Right Stuff". They sell it autozone in this easy cheese kinda can.
waddaya think?
[This message has been edited by V8Astro Captain (edited November 10, 2001).]
Old Nov 10, 2001 | 06:01 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
I've always had good luck with the UltraBlue sealant, it swells a little bit when it contacts with oil, I've used it on several intakes,valve covers and never had a leak, I always rough up the surface with a fine sandpaper and then clean it with a good cleaner(brake cleaner works good) so it will stick good.
92 Camaro RS 5.0 5-Speed (Quasar Blue)
T-Tops
14" Open Air Cleaner
3.08 Posi-trac
Edelbrock TBI Intake
Crane cam
Ported & polished stock heads 3 angle valve job
HyperTech Chip
UltraFlo cat-back exhaust
74 Dodge Dart Sport 360 (11.2 1/4 mile)
2000 Dodge 1500 Ram Sport
92GTA
Apr 9, 2016 07:39 AM
stalkier
Dec 6, 2015 11:25 PM
1985chevydude
Aug 20, 2015 12:29 AM
cstrobel65
Aug 15, 2015 10:19 AM
Street Lethal
Aug 12, 2015 11:33 AM
