Just wondering what running my 305 injectors on my 350 would be like with 20psi of fuel pressure??? I cant find the conversion for pressure and lbs/hr..Im running a little rich right now with the 350 injectors and 20psi, so I was wondering if going back to the 305's would help until the EBL arrives and I can tune my bpc??? Any Help or suggestions would be greatly appreciated!!! Im thinking that this would help for a temporary fix. But what are your thoughts????
Theyll work fine at 20 PSI, but they may also flow more then the 350 injectors at the stock pressure. The conversion to get the approximate new flowrate is: square root(new fuel pressure/old fuel pressure) x old flowrate.
Thanks again for you help Dimented!!! Your wise and have helped me a considerable amount as to this date. I apprecaite your advise. I think that using the 305 injectors is going to help out a fair amount until I can get the tuning side of things up and running. They will flow less than my 61lbs injectors at the same pressure. This will help because I can only get down to 17psi right now!! It should help to reduce my over rich condition slightly at this point?? Thanks again.
