Those who did the AFPR TBI mod.....
Old Nov 16, 2001 | 07:16 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Since I haven't pieced together a fuel pressure guage yet,
I was wondering how "high" the tab on the FPR needs to be for the best performance.
Old Nov 16, 2001 | 08:06 PM
JPrevost's Avatar
Car: 91 Red Sled
Tune it with the performance, not by any set value. They're all different anyways, you'll range at least 2psi and that's a BIG difference.
Get your hands on a scanner and adjust the fuel pressure until your BLMs are around 126, this will be slightly rich but it's better than being lean. Okay?
Old Nov 17, 2001 | 08:20 AM
Pukka's Avatar
Darn, I was hoping I could be lazy!!
Anyway, I've got a scanner in the garage collecting dust so I guess I'll get on it sonmetime next week.
Thanks!
Old Nov 17, 2001 | 09:33 AM
super chevy's Avatar
OK, I'm an idiot. What scanner do I need, and what the heck are BLM's?
SC
Old Nov 18, 2001 | 12:55 AM
Jza's Avatar
Jza
Any automotive scanner. In this forum, there's a topic "Free scan software.." that gives you a link to some software, and instructions for building an interface cable to connect your car to your PC. If you look in the DIY-PROM section, you can get links to several software and hardware (handheld) scanners, with approximate prices and part numbers.
BLM is short for Block Learn Mode, which is also known as "long-term fuel trim". This is expressed on a scale from 0 - 255, where 128 is the point where the fuel is not being added or subtracted.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
