Junkyard TBI/Harness/ECM
im trying to convert my carb over to a TBI setup. I have a quote on a complete tbi setup with harness, intake, ecm ,throttlebody ,sensors, pretty much everything. I was just wondering differences from year to year, like if one year you couldnt make custom prom chips because of the ecm type or something like that. I would guess the newer the better....right?
the tbi setup will be going on a 350, so I know that I will need 350 injectors since the 305 tbi setup has smaller ones....
thanks.
thanks.
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Mine's a 92, and I know the IAC connector is different on 91-92 models,so if you wanted to run a Holley Throttle Body,it would require the 90-earlier harness or an adapter.I'm not aware of any other differences,but maybe someone else knows.
You'll need the 350 Truck TBI Injectors:
Part#17112493
350 Knock Sensor:
Part#10456288
350 Knock Module:
Part#16128261
Hope this helps
-Rich-
[This message has been edited by RICH92RS350 (edited November 21, 2001).]
Part#17112493
350 Knock Sensor:
Part#10456288
350 Knock Module:
Part#16128261
Hope this helps
-Rich-
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Prom burning for the 88 ECU is currently not possible.. however, everything else is the same (you can get 88 parts and a 89-92 ECU too, harness is same, swap is no problem)
'88 Camaro, hunter green metallic, T-top
LO3 305 TBI/700r4
Performance mods: MSD Coil
Audio mods: Pioneer DEH-P3000, Pioneer 6x9s, Optimum 260 watt 3 channel amp driving 6x9's, prepping to build sealed glass sub box for single 12"
'86 Camaro, ultra silver metallic /w dark blue metallic racing stripes
2.8l MPFI/700r4 /w special 2nd gear delete option
Misc Mods: Cut air box, '83 Firebird spoiler.
Performance Parts: Accel 8mm wires, SplitFire plugs, Gabriel hijackers, poly swaybar bushings.
My Homepage, with pics.
LO3 305 TBI/700r4
Engine: LS1, Scrap
Also, check to see if there's a Painless wiring harness available.. I don't know about you, but I wouldn't put 100k+ mile wires out of a junked car into my car without expecting problems...
LO3 305 TBI/700r4
LO3 305 TBI/700r4
Damon
Sep 26, 2015 04:29 PM
