Injector Flow Rates, Color Codes, Pressures and Part Numbers
Old Nov 22, 2001 | 01:33 PM
89BlwnRs's Avatar
Just wondering if anybody has flow rates, color codes, part numbers and what pressure the flow rates are rated at, for TBI injectors. What rating is the stock 305 injectors, and what platform or part number can I get higher flowing injectors from.
Jason
Old Nov 23, 2001 | 09:27 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
its in this board somewhere. a long time ago, posted by me, that might help you find it
Old Nov 23, 2001 | 07:05 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
I'm still surprised that someone didn't take that table and make a tech article out of it. Must be because it was TBI info...
Jason, the chart will have everything in it that you need though, just do a search...
-=-Mike
1989 RS.. 355, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, rapidfire plugs, chevy caprice 350 chip, 200* fan switch, 3 angle valve job, 3 inch cat-back exhaust, 3 core radiator, 3.73 gearing with POSI.
Old Nov 23, 2001 | 07:21 PM
steve8586iroc's Avatar
Here's some reading you can do. https://www.thirdgen.org/messgboard/...ML/000790.html
1992 Trans Am
May 10, 2023 07:19 PM
lee01
Apr 9, 2016 01:56 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
armybyrd
Aug 10, 2015 09:23 PM
1nastygta
Aug 8, 2015 07:38 PM
