Code 32
Old Nov 22, 2001 | 07:49 PM
Milt Clapp's Avatar
Code 32
90 model 350 C.I. sets code 32 when running at moderate speed sometimes 55 to 65 sometimes 35 to 45 and not much load.
Changed the e.c.m vacumn control but it still sets the code and gives steady light till turned off. What gives and how does it set the code?
Thanks Milt
Old Nov 24, 2001 | 01:24 AM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
Did you inspect the two thin, stiff (ie easily cracked) vacuum hoses running (1) from your throttle body to the EGR solenoid and (2) from the EGR solenoid to the EGR valve on the intake ?
If those are OK, it's probably a bad EGR valve. I think the ECM is trying to open your EGR valve when you're cruising at those speeds after the car has warmed, but that's not happening, so it sets the 32...
Joel Geerling
Red 91 Formula, 305 TBI
Edelbrock 14x3 open element
TBI 1/2" spacer
Hypertech street chip
Crank/Alt Pulleys
Exhaust is next!
Old Nov 24, 2001 | 11:09 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
OR the hoses and vale is prolly fine just the passages for the EGR are clogged up with carbon.
I was getting the code 32 off and on for a while till when I had to pull of the manifold on my car. Then I saw all the passages clogged up with carbon.. Cleaned them all out and now I havent had a problem since the begining of the year with a code 32
Kat
Old Nov 24, 2001 | 08:30 PM
vjo90RS8's Avatar
Car: 2002 Z28
I also have gotten code 32, but i only get it when i am in overdrive. I drive 250 miles from school for Thanksgiving brea and no SES light but then i drive 10 miles in overdrive and i get the code. This is the third time it has happened but i havent had time to check anything yet. why is it only when im in overdrive. THANKS for the help.
1990 5.0 TBI
1 5/8" Edelbrock TES headers, 3" Catco hi-flow series cat, 3" Hooker Aero-chamber cat-back, K&N 14x3 flat based open element, MSD 8mm Heli-Core plug wires, cap, rotor, and coil, AC delete
Next:
Spohn sub-frame connectors, SLP take-off posi, 3.73 Richmond gears, Ultimate TBI mods
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
