88 TBI Idles Rough/Stalls when Cold
Old May 17, 2007 | 02:51 PM
scarello's Avatar
Car: 1991 Camaro RS Convertible
Engine: 305ci
Transmission: 4-Speed Auto
Any good starting points to check why my 88 Idles Rough and even stalls when cold, but given a five minutes or so straightens out?
It also smells like it's running extremely rich as well.
Thanks in advance,
Steve C - RI
Old May 17, 2007 | 03:11 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: 88 TBI Idles Rough/Stalls when Cold
Start with by check CTS - it maybe faulty.
//RF
Old May 17, 2007 | 05:12 PM
The White Knight's Avatar
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Transmission: 200C 3 Speed
Axle/Gears: 2.93 Open Diff
Mine did this same thing, tried CTS and MAT, no change
Timing was 4.5* retarded!
Set it 4.5* (base) advanced
Its awesome now!
(Was only when it was cold to, pull up to a stop sign, it would almost stall then catch itself, and sputter when giving it the gasd, but get alot better when warm, all it was was timing)
Old May 17, 2007 | 05:35 PM
scarello's Avatar
Engine: 305ci
Thanks,
I'll check that out.
Steve C - RI
Old May 17, 2007 | 07:22 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
yeah check that out.
Anthony R.-Killa cali
Old May 17, 2007 | 07:41 PM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
My TBI unit was leaking. It would slowly dribble down one barrel, as evidenced by the thick layer of black goo around that area. Just something to keep in mind.
It would hard-start when cold, miss slightly at idle when warm(but only at idle), and occasionally stall when car warmed up and super cold out.
QUOTE: "It also smells like it's running extremely rich as well."
Biggest clue right there. Make sure timing is correct(and ignition working properly!), and look for fuel leaks. No leaks?? Well, then I'd look at why the computer is dumping in more fuel than your need.
Or(worst case scenario), your engine isn't getting the air it's used to. Thats usually the hardest to fix.
MustangBeater20
Oct 29, 2022 09:20 PM
Wade787b
Sep 29, 2015 01:15 PM
86IROC112
Aug 21, 2015 07:20 PM
92camaroJoe
Aug 13, 2015 06:07 AM
