Will This Fit My 89 (Manifold Choices)
Old May 21, 2007 | 11:19 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
http://store.summitracing.com/egnsea...splayPrice%7C0
Which of these will fit because I know some have different hole configurations.
I am also buying a Holley TBI adapter plate....as well as my open element and gaskets of course.
Old May 21, 2007 | 01:35 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Re: Will This Fit My 89 (Manifold Choices)
You're gonna have to do a bit more research on your own before some one will help you. No one is going to take the time to dig through the summit catalog and tell you which intakes will work and which won't.
I'll give you a hint, the height of the intake is very important....
Old May 21, 2007 | 01:51 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Well everyone tells me to go with carburetor manifolds but not which ones? The only one everyone uses is the edelbrock performer or others which need different heads.
Also Summit nor many sites like Edelbrock and Holley dont state height of manifold....so unless you have a site I can check height on I am still going to need to know by experience which ones work with the LO3. Thank you for your time.
Old May 21, 2007 | 02:30 PM
BMmonteSS's Avatar
Car: 84' Monte
I don't mean to sound like an ***, but a simple search for (TBI intake manifold) on this board will give you several hundred threads to browse through. You'll quickly find that the angle of the center 4 bolt holes really isn't that big of a deal and an angle grinder and some washers will let you use any head with any intake.
You'll also find that the performer RPM is the intake of choice but it's too bad it's a tad too tall, so guys tend to bounce between a low profile single l plane or a low profile dual plane.
Old May 21, 2007 | 02:47 PM
Ronny's Avatar
i thought Holley and Edelbrock show the height on their site?
Weiand low rise single plane #7547 with adapter plate is an option.
i run a Holley high rise TBI manifold on my Vette but may not clear your hood.
Old May 21, 2007 | 03:01 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
I have a new Daytona Hood....another 2-2.5" of clearance....and if anything Ill relocate my ign coil and be able to put a drop base on it and that will give me another 1.25". Let me know guys....going to search again.
anesthes
42
Oct 24, 2015 07:30 PM
zayne0
Aug 24, 2015 07:22 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
theurge
Aug 21, 2015 12:46 PM
