Cleaning Your Stock/Holley TBI Unit
Old May 24, 2007 | 01:28 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I am replacing my intake manifold with an edelbrock manifold and was wondering how could I clean up my stock TBI without having to take it apart...
Basically can I soak it in an alcohol or something? Or spray it with engine degreaser then wash clean and let dry for 1-2-3-4-5-6-7 days to ensure no water is still on it or in it?
Thanks guys.
Old May 26, 2007 | 10:48 AM
1badz71tahoe's Avatar
Re: Cleaning Your Stock/Holley TBI Unit
Thanks guys.
You have a couple choices.
First of all, water doesn't cut grease, unless you want to mix some simple green with it or something.
I would suggest:
1. Gasoline (Please do this outside in the middle of your driveway in the dirt, or on the pavement, WAY AWAY FROM ANYTHING THAT CAN CATCH ON FIRE BECAUSE I DON"T WANT TO BE LIABLE FOR YOUR DEATH, more importantly i don't want to hear you dying because of something happeneing).
2. The safer but more expensive method is to get a gallon of "Gunk Parts Cleaner" from the local auto parts store.
Let us know if you have any other questions.
Take Care,
- B
I almost forgot, grab your childrens old tooth brushes, or the one for the dog.
I like to save the old toothbrushes and throw them in the dishwasher a few times and keep them in my shop for just this reason! If you want to burn some money go buy some new ones, or get some cleaning brushes from the store when you go to get the gunk parts cleaner.
Old May 26, 2007 | 11:30 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Last time I had mine off I took off the whole TBI from the manifold, and took it apart, removed the injectors, set them aside, removed all sensors, scraped off all the old gasket material, cleaned every piece throughly with a toothbrush and gasoline in a large oil catch tin, and re-assembled it with a $7 TBI gasket kit from Autozone. It was fun, I'd recommend it. Don't do it indoors. Make sure you get inside all those vacuum ports on the underside of the base...they tend to get really full of crap. Gasoline is the perfect thing to clean with, its cheap, it evaporates in no time at all, and you don't really have to worry about get drying it all out because a lot of the TBI unit is coated with gasoline during normal operation anyway.
Old Jun 21, 2007 | 08:40 PM
Rocket-Doc's Avatar
Car: 1990 RS/SS modified
Engine: 355ci, 113 heads, LT4 hotcam
Axle/Gears: 3.73 Eaton posi
I like using kerosene....
works well.....
Old Jun 21, 2007 | 09:03 PM
CJMurray's Avatar
Car: 93 Jeep Wrangler
Engine: 350 tbi
Axle/Gears: Stock 4.10's
Any suggestions for a Holley injector that drips occasionally? I've actually only seen one drop fall while in operation, but I figured there must be a bad o ring in there. While I'm cleaning it out, will an o ring fix this problem?
Old Jun 23, 2007 | 07:49 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Naphtha (AKA lighter fluid) also works very well as a degreaser and is relatively inexpensive.
CJ, what year is the holley? Does it have teh black caps on top of the injectors?
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
92camaroJoe
Aug 13, 2015 06:07 AM
