about how muxh horse power will it make
Old May 31, 2007 | 10:57 PM
andrewt1021's Avatar
ok heres what i have its a 94 s10 with 94 350 bore 40 over with 1992 350 tpi carmao ROLLER cam and heads that are ported it has a holley proformer tbi intake . chevy 350 tbi 2inch bore 60lb injector with 4l60e TRANS no egr has header with 3" exhust and 3inch cold air intake
Old Jun 1, 2007 | 07:10 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Re: about how muxh horse power will it make
How much tuning have you done?
Which TBI unit are you using?
What are the specs on the roller cam?
Which heads did you port?
These are the types of things we need to know to make an educated guess as to what kind of power you are making.
Old Jun 1, 2007 | 08:46 PM
How much tuning have you done? a ton of tuning 25 hours of test and change it all in tune
Which TBI unit are you using? a stock tbi bored over to 52mm with 60 lb injetors
What are the specs on the roller cam? stock 92 350 HO CAMARO tpi roller cam
Which heads did you port? stock 92 tpi 350 HO camaro heADS
Last edited by andrewt1021; Jun 1, 2007 at 08:48 PM. Reason: Automerged Doublepost
Old Jun 2, 2007 | 11:23 AM
BMmonteSS's Avatar
Car: 84' Monte
I'd venture to guess you could be making around 260hp or about 220 at the rear wheels. Should put you solidly in the mid 14's.
jhawkeye
May 25, 2022 06:33 PM
theshackle
Sep 17, 2020 08:26 AM
italiano67
Dec 11, 2016 09:21 AM
86White_T/A305
Aug 17, 2015 12:16 AM
novaderrik
Aug 10, 2015 12:44 PM
