lt1 Heads
Old Jun 6, 2007 | 09:42 AM
The White Knight's Avatar
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Transmission: 200C 3 Speed
Axle/Gears: 2.93 Open Diff
lt1 Heads
I can get a good deal on lt1 cam/lt1 heads..
Using 350 lt1 heads on a l03 305 isnt a good idea right? as compression will drop...
wouldnt consider doing this right/
Old Jun 6, 2007 | 10:41 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Re: lt1 Heads
Compression is the least of your worries. The LT1 head is a reverse cooling head and uses a different intake and block than an old school small block.
Guys have used LT1 heads on gen 1 blocks, but it requies extensive welding and machining and is NOT cost effective as a swap. Vortec heads will make more power and only cost 500$ brand new. They will drop your compression slightly but the power gain WELL offsets any loss from the compression.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
midge54
Sep 2, 2015 06:27 PM
midge54
Aug 29, 2015 09:51 PM
Redwhisper
Aug 26, 2015 05:02 PM
