stock L03 TBI fuel pressure question
Old Jun 23, 2007 | 09:21 PM
escort_ford84's Avatar
Im running a 1988 camaro TBI L03 w/mods. Injectors were going static @ 4 grand (I tune and burn my own chips). I went in and changed the regulator spring from stock to a TPI regulator spring and made it adjustable. With the adjustment all the way down, my fuel pressure is right at 28 PSI. Is this pressure ok or is it too much for TBI? I ran it a tad and there is no leaks. I know the big block tbi's run at like 18-20 PSI. I know i need bigger injectors, but this will have to do till i get them.
Thanks,
Michael
Old Jun 23, 2007 | 09:28 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: stock L03 TBI fuel pressure question
Thanks,
Michael
I know that my Marine TBI regulator was setup to run at 30 PSI of fuel pressure. If your regulator diaphram is fresh as well as the O-rings, 35-40 PSI is not out of the question. If you plan to exceed 45 PSI, you need to block off the stock GM regulator and go to an external EFI bypass type regulator.
Old Jun 23, 2007 | 11:32 PM
Hey thanks man. Ill keep it like it is and tune it now.
Old Jun 30, 2007 | 10:30 PM
Im not a complete moron (lol) but.... could someone check my math? Im having trouble with the BPW. For some reason my car is running horrible at light throttle. Injector is the *279* (L03). Original fuel pressure was around 12 psi. my new fuel pressure is 28 psi. I come up with an Equiv. injector of #76 (76.37 flowrate). I came up with a 102 BPW. This is a L03 engine that i shift @ 6500 rpms. i posted this in the wrong thread, i cant figure out how to fix this.
Old Jul 1, 2007 | 08:20 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I typically use 13 psi for the base flow rate. For those injectors (55 #/hr) at 28 psi they will flow about 80.7 #/hr for a BPC of 90 and an engine CI of 305.
For the light throttle issue, is it surging? You may need to reduce the proportional gains, and slow down the INT update rate some.
RBob.
Old Jul 1, 2007 | 02:35 PM
thanks RBob.
Old Jul 1, 2007 | 11:11 PM
i set my BPW to 90 and its running MUCH better. Thanks again RBob.
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
R3500
Aug 17, 2015 12:16 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
