Question on the other type of TBI Spacer
Old Jul 3, 2007 | 11:13 PM
Tobashadow's Avatar
The one that goes on the injector pod not under the entire unit.
I can get around $12 shipped to me.
Anyone have any experince with them?
And how hard to install.
Old Jul 4, 2007 | 10:18 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: Question on the other type of TBI Spacer
A flat base airfilter housing should give you 20x more gain.
If you are using the stock air cleaner with cut away silencer ring it allows a little more air in. But you could use the 12$ to make it a flat base.
Old Jul 5, 2007 | 01:25 AM
slow89's Avatar
Car: 89 irocz
Axle/Gears: 373
i had just recently put that injector spacer on my car it only talkes about 10 min. but its a pain in the *** to get the fule lines screwed back in but idk if its worth it beause when i was installing it i cracked my injector pod so idk if it is worth the money or not.
Old Jul 5, 2007 | 11:59 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
I have done it, its a pain in the butt actually because of the fuel lines, you really need to put new orings and the lines and you should use a proper line wrench and i didnt really feel any hp difference its just a mixture of a couple things that give your car HP. I just put a hypertech powercharger and kn flowthrough top filter on it and now i feel a nice HP gain, or seat of the pants throttle change.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
customblackbird
Aug 15, 2021 10:16 PM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
