which wire?
Old Jul 7, 2007 | 10:28 AM
ad356's Avatar
Car: 1989 camaro rs
Engine: 305 tbi
Axle/Gears: 3.23 lsd swap
which wire?
im doing my timing today. i need to disable the computer advance. i noticed on wire that near the distrub, i discovered it runs the factory tach. which one disables computer advance. i also read if you jump the diagnostic wire to ground on the ALDL connector (diagnostic connector) it will also disable computer advance. which is the best way?
Old Jul 7, 2007 | 10:52 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Re: which wire?
The only way to disable the ECM control of timing is to uhook the brown wire with the black stripe. There is a single weather pak connector near the heater box, that's the one to unhook.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
