where do i get a special tool for timing
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i noticed in my haynes that i need special tool to time my car because it has the magnetic timing probe. where do i get them ?
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Re: where do i get a special tool for timing
It has provisions for a magnetic timing probe, but as far as I know only the factory actually owns one of those machines. Stick with a timing light, just make sure you unkook the est wire.
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
I actually found a mechanic in our neighborhood that tried thought he knows everything about f-body cars. But, he told me you don't have to unplug the est wire. I bit my tounge and watched as he adjusted the distrib to 6 deg. He then told the owner that it had a faulty distrib shaft and it would cost them like $175 more to replace. I caught up with the owner later that day and explained the real deal to them. Yes, Use a timing like on the NO# 1 plug, it is the easiest way to go.
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
after talking to a few gm mechs ,they said that haynes manuals are full of it and all i need is to unhook wire and use ordinary timing light.
Car: check
Engine: check
Transmission: check
Stock timing with the EST open is 0 deg (TDC).
Sometimes a little better performance can be had setting the timing a few degrees advanced, say 2 - 4 deg BTDC.
RBob.
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
I thought that I read in the Chilton manual or maybe Haynes that to set the timing on a TBI you needed to jump A&B on the ALDAL. It said to unhook the EST on TPI only. I need to see if I can find that one.
Anyone else ever hear that one.
Car: check
Engine: check
Transmission: check
RBob.
backtothe80s
Sep 5, 2015 12:39 AM
383backinblack
Aug 15, 2015 06:36 PM
