1990 305 TBI help!!!!
Old Jul 8, 2007 | 03:18 PM
vizracer's Avatar
ok so i have a 1990 camaro it has the stock 305 in it.....so far i have removed the AC with a ac bypass kit and i have removed most of the A.I.R pump stuff. i have a set of flowtech headers that im going to install within the next week or so i have removed the stock air intake and put one off of a old carbed motor on it(open air). my question is about my heads and my intake.....i dont care a whole lot about major performace just little stuff since the car is getting a new motor this winter and this motor will be in a DD blazer, but what heads can i run that will be better...would the vortec heads off of a 350 truck work? and do i have to do any ecu changes if i put the TBI off of a 454 on there?
Old Jul 9, 2007 | 02:03 AM
M1tch's Avatar
Car: 1989 Iroc Z
Engine: 496 BBC
Transmission: th400
Axle/Gears: 4.11
Re: 1990 305 TBI help!!!!
The Throttle Body Unit should be fine if you were to put heads on. But without a cam your powerband will be out of whack and without tuning you wont get the full potential out of the heads, yes the vortec heads will fit.
xkingcodex
Feb 12, 2020 07:43 PM
Dwayne614
Sep 28, 2015 08:33 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
CamaroGuy350
Aug 26, 2015 05:11 PM
