Knock Sensor Question
Old Jul 11, 2007 | 03:32 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
Alright....I got an answer over on the engine swap...but I want to hear it also from the TBI GURU's on here.
My question is in regards to Knock sensors and what I should be using for my 350 (with a hyd Flat Tappet cam) which is going in on the weekend. Will a knock sensor for a L98 car work fine? Some have told me it will...while others have told me that I need a Knock sensor for a Car (350) which has as Hyd Flat Tappet Cam. So what is the right answer??? And if it is the latter which cars came with a 350 and those so I can look it up?
TBI GURU's I ask for your guidance!!!
Thanks,
Dave
Old Jul 15, 2007 | 02:14 PM
HiPerf_Chevyman's Avatar
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
Re: Knock Sensor Question
Gotta Think about the Computer... if your computer supports a HFT Cam, you'll want that knock sensor for that. If it doesnt support the HFT cam, a regular 350 L98 is what your looking for. However the Best thing would to Burn a Chip yourself and get a HFT cam Knock Sensor..
bamaboy0323
Sep 3, 2015 06:07 AM
db057
Aug 22, 2015 08:17 PM
redmaroz
Aug 16, 2015 11:40 PM
gwade12
Aug 8, 2015 08:17 AM
