air injection reactor pipe?
Old Jul 15, 2007 | 09:43 PM
Dispute's Avatar
Ihave an 89 camaro rs with a 5.0. My car has been making a chirping/squeeking sound since ive owned it (about a month), until a few days ago i thought it was the ac compressor. But the other day i noticed that the check valve that is connected to the air tube on the passenger side exhausr manifold is broken off. I kind of have a few questions about that... first am i risking anything by driving my car with it broken, and also im not fammiliar with this system can somebody explain its importance (all i know is that its emmisions related), and lastly how do i go about eliminating it, im not really planning on doing that but im curious because some headers dont have it and i wonder what people who get those do about the rest of the system.
Thanks in advance to anyone who can answer any of my questions.
Old Jul 16, 2007 | 06:05 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: air injection reactor pipe?
The squeaking is the air pump. Sounds like its toast. The passenger side exhaust valve likely wont do much harm with manifolds. With headers, it could suck lots of air in at WOT and overheat teh cat. It will, however, allow exhaust to enter the engine, and possibly passenger compartments.
For taking it off, do a search for smog pump or air removal. LOTS of threads on this.
Old Jul 16, 2007 | 07:32 PM
Dispute's Avatar
Are you sure the air pump is toast, because i held the two broken pieces together while the engine was running and the noise stopped, and the nise also soulded like it was coming from the broken valve?
But thanks for the info, although im not really planning to remove the system (at least not now) I was curious about how to remove it and how it worked.
Old Jul 16, 2007 | 09:24 PM
Car: 88 Camaro SC
Engine: SFI'd 350
If the pump itself isnt making the noise, then its ok, but if the noise is coming out of the line leading to the air pump or the pump itself, then it may be faulty.
Old Jul 17, 2007 | 06:27 PM
Dispute's Avatar
oh okay, thank you. Now im considering actually taking the smog pump off if its gunna keep costing me money.
87iroctheo
Dec 4, 2016 11:47 AM
toronto formula
Nov 10, 2015 06:17 AM
z28addict8490
Sep 5, 2015 03:56 PM
FreeSpirit
Aug 29, 2015 05:47 PM
db057
Aug 22, 2015 08:17 PM
