help
Old Aug 8, 2007 | 06:01 PM
80sBaby28's Avatar
Car: 1989 camaro
Engine: v8 fuel injection
Transmission: automatic
help
I have an 89 camaro that has a 305 in it and the owners before me switched out the tbi and made it a carb. I have to switch back to tbi in order to pass smog and I was wondering what all do I need to buy and where online I could by these parts. Any help would be great and a big help thanx
Old Aug 8, 2007 | 08:09 PM
90c350's Avatar
Re: help
Do you currently have the OE computer?? Or do you know where to find it?? Is there any of the original wirring in the engine compartment?? Does it still have the oe tranny? We will need to know how much of the orignal wirring and ecm and parts that are still there in order to help you a little more. You can try the wreckers for a throttle body and injectors, Anything of your style car or a tbi truck will work. If you cant find your ecm you could rob most of the stuff from the wreckers and go from there. Truck tbi stuff will work for you as well incase you cant find anything for a camaro. I hope that this helps a little??
Old Aug 8, 2007 | 08:10 PM
Brandon2350's Avatar
Car: 1993 Z-71 pickup
Engine: Heavily modified 355 on TBI
Transmission: Had a 4L60e. Now a 700R4
Axle/Gears: Bone Stock
Re: help
Depending on what was removed it could be numerous...ECM? Sensors, TBI unit, ect. My sugestion would be to check the stickies on this site
