fuel filter install?
hey guys i tried to search where the fuel filter is located and info about the install, but no results spefically talking about it...ne help please, thanks. its on a 89 305 tbi camaro.
Car: 88 firebird
Engine: 305 TBI
Re: fuel filter install?
My haynes manual is for the Camaro and it says the location is on the passenger side of the block near the bottom. I know it isn't in that location for my Firebird, and a lot of other people say it is near the back axle on the driver side. Jack up the rear and take a peek under.. you should be able to see it if its there.
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
on my 89 305 t.b.i. its located ,drivers side , between gas tank and rear axle . dis-connect battery , wd-40 fittings and clamp bolt . be prepared for some gas leakage . once again dis-connect battery , if not fuel pump could come on and then you have a big problem .
1992 Trans Am
May 10, 2023 07:19 PM
92camaroJoe
Aug 13, 2015 06:07 AM
