k, finally got a v8...now i need some help
Old Sep 2, 2007 | 06:52 PM
2tonedmaro89's Avatar
Car: '91 RS
Engine: 5.0L gross *** tbi
i started switching plugs and i did about 2 also cap and rotor.....went for a drive and now my car just stalls out when i get off the gas but when i get on the gas i get lots of blk smoke and stall... my check engine light is now on. wth?
its a 91 rs 305 tbi 700r4
Old Sep 2, 2007 | 07:07 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: k, finally got a v8...now i need some help
What exactly was done? New plugs, wires, and cap and rotor? If so, check teh firing order. Sounds like you crossed some wires.
Old Sep 2, 2007 | 07:20 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
more info , just exactly what did you do prior to this ? sounds like someone pulled a boo , boo . thats the best way to learn , by your own mistakes . no flame , but any day with out learning at least one new thing is a wasted day .
Old Sep 2, 2007 | 10:30 PM
Car: '91 RS
not wires yet lol ....just 2 plugs, cap and rotor lol
Old Sep 3, 2007 | 12:02 AM
Car: 88 Camaro SC
Engine: SFI'd 350
Which plugs did you change? Did you disturb anything around the distributor when you changed the cap and rotor? Are you sure the firing order is correct? It sounds like the firing order may be way off, or something was knocked loose when you were working on the car.
Old Sep 4, 2007 | 04:32 PM
Raiderfan's Avatar
Car: '92
The cap can sometimes be a pain to get back on FLUSH. I would check that first.
Old Sep 4, 2007 | 05:22 PM
F-Body Demon's Avatar
I think you moved the distributor. Hit it with a timing light and see. $29.99 at Autozone, good investment if you dont have one.
Rocket-Doc
Nov 14, 2015 02:08 PM
Antips16
Oct 30, 2015 06:42 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
