stalled out at a light today, help
Old Sep 11, 2007 | 02:05 AM
mr. maro's Avatar
Hey guys i was at a red light today and my 1989 camaro 305 tbi just stalled out, but it started right back up. Any ideas on what could cause that, please help
Old Sep 11, 2007 | 02:17 AM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: stalled out at a light today, help
do you have cold start probelms? was your A/C on? did it stall as soon as you stop or did it idle for a while? how much gas was in it? sorry so many ????'s just need more info
Old Sep 11, 2007 | 02:40 AM
mr. maro's Avatar
well wen i start it after sitting overnight, it will idle around 1500-1800 for like a min or 2 and then drop to around 750. the a/c wasnt on. the gas gauge is off but id say prob about 1/4 tank in it. and i was stopped at the light for about a minute maybe.
Old Sep 11, 2007 | 02:50 AM
89RS_82Z's Avatar
hmmm not to sure, sometimes if you are REAL low on gas it will all slosh foward on a stop and sometimes cut out.......mine has done that a few times, im not to worried about it, i know i need new injectors but im holding out to get a holly or other oversize TBI.....if the idle is real low in gear and on the brake then you may want to raise it a bit, in case you dont know how look at where the throttle thingy is and you will see a stop screw, look infron of the TB unit where the head of that screw would be, you will either see a screw of a silver "plug" just take a scratch awl and a hammer and tap into that plug and pry it out, you will see the screw and adjust accordingly..... not sure if you got a injector problem as you would probably have hard cold starts where you got to hold the idle. wish i could be more help
Old Sep 11, 2007 | 03:05 AM
mr. maro's Avatar
thanks a lot for all of ur help, i will check all of that out. hey u can chirp the tires in 2nd with the 2.73's...u must have a good tranny or some good mods.
Old Sep 12, 2007 | 03:16 AM
89RS_82Z's Avatar
totaly custom built 700R4 by one of the best 700R4 builder within 200 miles of me, really strong motor for a 305 TBI, got a real good suspension also
Old Sep 16, 2007 | 08:29 PM
mr. maro's Avatar
bump
92camaroJoe
Jul 29, 2023 07:57 PM
spaigo
Aug 21, 2015 07:46 PM
Fronzizzle
Aug 17, 2015 02:52 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Omega
Aug 10, 2015 12:46 PM
