car barely idles and wont run in gear
Old Oct 21, 2007 | 02:06 PM
walight01's Avatar
i have a 91 tbi 305. block and heads were both just rebuilt. car will barerly idle, it doesn't idle smooth at all. i replaced the map, ecu, coolant sensors, cap, rotor, coil pack. i cleaned the iac and egr valve. im getting codes 23,33,34,42. i've checked all the wires and vac hoses the best i can. code 42 says bad ignition but its over a hundred bucks and i don't want to buy one if thats not the problem. any other ideas?
Old Oct 23, 2007 | 09:53 PM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Re: car barely idles and wont run in gear
Did your problems happen immediately after you had all that work done?
Old Oct 24, 2007 | 08:15 AM
walight01's Avatar
The car ran great for the first two weeks after the rebuild. Then it went downhill slowly to this point. It fouls plugs quickly.
Old Oct 24, 2007 | 08:41 AM
bigj350's Avatar
Try getting a vacuum tester. I got mine from harbor freight for about 10 bucks. Check that single tan wire that puts the est in bypass mode also. Code
42 can be set off by that being unplugged. Also, I think autozone can test your ignition module for you. I think I got an extra one if its is bad.
Old Oct 24, 2007 | 08:45 AM
walight01's Avatar
I've checked the vacuum pressure and it's good. That wire is plugged in. When I get back home I'm going to pull the ignition and take it to Advanced or AutoZone. Do you know if the pick up coil is adjustable?
Old Oct 25, 2007 | 02:24 PM
bigj350's Avatar
That I dont know.
Old Oct 27, 2007 | 09:35 AM
Brandon2350's Avatar
Car: 1993 Z-71 pickup
Engine: Heavily modified 355 on TBI
Transmission: Had a 4L60e. Now a 700R4
Axle/Gears: Bone Stock
A valve adjustment or your adjustment backing off would cause a rough idle to worsen over time also...(also triggering codes) Have you rechecked your valve lash?
Old Oct 27, 2007 | 01:25 PM
walight01's Avatar
i havent checked the valve lash. i measured the injector resistance and got 1.2 on one and 1.3 on the other. i took it all apart and cleaned it and put it back together. i got eye leven and noticed that both injectors spray a cone, but not the same cone, one is bigger than the other. and when i open the throttle, the cones both turn into a straight stream down into the throttlebody. only at idle to they remotly spray cones. would this mean bad injectors or bad fuel pump. autozone wants 45 bucks for a fuel pressure tester. noone rents them anymore.
the ignition checked out fine
specialized
Jun 18, 2022 09:26 AM
AkDrifted
Aug 17, 2015 07:45 PM
86IROC112
Aug 17, 2015 02:00 PM
mizz0313
Aug 12, 2015 06:45 AM
killer777
Aug 8, 2015 02:47 PM
