TBI ?
Old Nov 3, 2007 | 09:28 PM
camaro55427's Avatar
Car: 89 Iroc z
Engine: 350 carbed
Transmission: built 700 R4 2200 stall
Axle/Gears: 3.73 10 bolt
TBI ?
is a tbi unit from a mid 90's cadilac 5.7 liter the same as any other 5.7 liter gm tbi unit and has the 64 lbs injectors?
Old Nov 4, 2007 | 10:01 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: TBI ?
The Caddy TBI units are interesting. They have a small curved ring under the injectors. Probably there to improve low speed driveability. As it will create a low pressure area which will help shear the fuel into a finer mist.
Not sure what size the injectors are. Could always get one and try it out. Also note that I don't believe they have an IAC. The ones I've seen use a idle motor on the throttle linkage. This would eliminate the loud hissing from teh IAC passage.
RBob.
Old Nov 4, 2007 | 10:17 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: TBI ?
RBob.
If it truely is a 5.7 it is a Small Block Chevy 350. That would have the same TBI unit as a 5.7 truck/van/suv/B-car. Should have 61# injectors, although I have seen some 55# injectors in the 180HP models.
Old Nov 4, 2007 | 02:50 PM
Car: 89 Iroc z
Engine: 350 carbed
Re: TBI ?
sounds good, i grabbed one from a yard near me and i wasnt sure if it was right but ill try it and see wat happends thx
Old Nov 4, 2007 | 09:19 PM
Car: 89 Iroc z
Engine: 350 carbed
Re: TBI ?
is there ne way to check the injectors to make sure their 61#?
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
