i need help
Old Nov 11, 2007 | 09:19 PM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
i need help
I have 92 Camaro 305TBI with 700r. When you put the car in gear it dies. I have checked for vaccum leaks lines brake booster intake ect no leaks or crimped lines.Replaced the TCC solenoid and torque converter. I have no codes when scanned. I have replaced the ECM, MAP sensor, TPS, IAC, EGR and O2. I have good fuel pressure and rebuilt the TBI. And did a complete tune up. Car doesnt miss or hesitate and has plenty of power when your driving it.The only way I can keep the car from dieing is to turn up the idle screw until the car idles at 1500 rpms and then it drops to 700 rpms in gear. I have even ran a can of seafoam through the intake and one through Throttle body to see if this would help. I tried unhooking the CAT and still same old problem. My only other thought is the park neutral switch. Does anyone else know what it could be.
Old Nov 12, 2007 | 01:22 AM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
Re: i need help
You seemed to have taken care of what I would have done first. The neutral safety switch just keeps you from starting it in gear. What kind of converter did you replace it with?
Old Nov 12, 2007 | 06:57 AM
royslsbry's Avatar
Car: 1992 RS
Transmission: 700r
Re: i need help
the neutral safty switch sends a signal to the tcc solenoid and a signal to the ECM which should go to IAC to idle the car up? But I am not sure if I should change it I also have thought maybe under the egr the intake could be stopped up. I wondering if my prob is in the intake.
