L03 aftermarket oil pans
Old Nov 12, 2007 | 06:15 AM
Parts4sale's Avatar
i want a circle track type pan with traps and baffles but all the oil pans iv seen for cheap say they fit 55 - 75 engines, what pan will i need that will fit, and be run with a lowerd car, also is the l03 a 1 or two peace seal?
thanks in advace
Old Nov 12, 2007 | 06:05 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
Re: L03 aftermarket oil pans
Cheap, and what you want probably shouldn't be used in the same sentence.
I would look at the Canton RR pan, but it is a bit pricey. L03's are 1 peice rear mains.
--John
Old Nov 12, 2007 | 08:09 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
I went through the trouble of using a "champ" style circle track pan that was advertised to be baffled for both right and left turns. I even added extra baffeling and notched my crossmember. The result was a pan that made me loose oil pressure under even moderate braking......canton is the best.
Unless you are really serious you would be better off with the stock pan and an accu-sump system.
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
carattini
Sep 10, 2015 07:46 AM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
